Activity › Forums › Apple Final Cut Pro Legacy › How to check duration of a certain part of a sequence?
  • How to check duration of a certain part of a sequence?
    Posted by Joewi Verhoeven on February 8, 2011 at 7:16 am
    The method I use now is copying the part I want to know the exact duration of, create a new sequence, pasting it in there and then checking the sequence duration. This way however seems a little farfetched to me, I’m sure there’s a faster way of checking the exact duration of a selected part of the sequence?
    Thanks in advance.
    Scott Sheriff replied 15 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    February 8, 2011 at 7:53 am
    Mark IN, mark OUT…look at the timecode window on the upper left of the Canvas..or the Viewer. That shows you DURATION.
    Shane
  • Joewi Verhoeven
    February 8, 2011 at 9:56 am
    Thanks a lot Shane!
  • Scott Sheriff
    February 9, 2011 at 10:55 pm
    “The method I use now is copying the part I want to know the exact duration of, create a new sequence, pasting it in there and then checking the sequence duration. This way however seems a little farfetched to me, I’m sure there’s a faster way of checking the exact duration of a selected part of the sequence?”
    Double face-palm! Have you read the manual?
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
    You should be suitably impressed…
