Activity Forums Adobe Premiere Pro how to change”interpret footage” defaults
  • how to change”interpret footage” defaults
    Posted by Lou Cannizzo on March 7, 2010 at 2:27 pm
    Hi all,
    Every day when I bring in a tga sequence, Premieres’s default is set to 29.976. Is there a way to change the default 29.976 to 23.976?
    For example,
    If you import a TGA, right click, inerpret footage, is is set by default to 29.976.
    Lou
    Lou Cannizzo replied 16 years, 6 months ago 2 Members · 2 Replies
  • Danny Winn
    March 7, 2010 at 5:45 pm
    If you’re using HD then the frame rate is chosen when you set up the “new project settings”, but I don’t think you have that option with Standard Def, only “Wide” or “Standard” dimentions option if I recall.
  • Lou Cannizzo
    March 7, 2010 at 8:05 pm
    yes I am importing 1440 x 1080 targas into an HD timeline.
    I went into Project settings & prefrences, but didn’t see it
    Also, my timeline is set to 23.976, so why would it assume that it’s 29?
