Activity Forums Adobe After Effects How to change your green screen background
  • How to change your green screen background
    Posted by Tyler Smith on December 29, 2011 at 10:31 pm
    How can I change my green screen background in the editing process, to a different color like white,black, or purple. I know how to key out the green screen i just want to know how to change the color after i’m done keying out the green screen and leaving the subject still their.
    Rousselos Aravantinos replied 14 years, 8 months ago 3 Members · 3 Replies
  • Rousselos Aravantinos
    December 30, 2011 at 2:39 pm
    1. Find the hue and saturation filter
    2. select the green input
    3. shift it to the desired color.
    U may have to control also some values for the :red / yellow/ cyan in order to achieve better results.
  • Michael Szalapski
    December 30, 2011 at 3:42 pm
    If you’ve already done the key, you could just put create solid and make it the color you want and put it below your keyed layer.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
    December 30, 2011 at 4:44 pm
    in this case the key should be perfect.
    Otherwise semi-transparent areas would reveal all the compression,
    especially over a black background (in most cases)
    So Tyler u r ok with keying i assume. Your question is all about compositing?
    ( placing the background layer below the keyed footage directly in ur editor )
    If this is all about then Michael’s advice is the proper one.
