Activity Forums Adobe Premiere Pro How to change Timeline display to min,sec,frames?
  • How to change Timeline display to min,sec,frames?
    Posted by Doug Zimmerman on November 16, 2012 at 5:40 pm
    Hello, my Timeline has somehow gotten switched over to just raw frame numbers from 1 to 100,000+. How can I change this? I went to Project Settings and chose frames. Ctrl-clicked on the frame display to make sure it says frames, even trashed the Prefs, but the problem persists – just a straight progression of frame numbers without being divided into min,sec,frames.
    Thanks for your thoughts . . .
    Lubem Ajiva replied 8 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jeff Pulera
    November 16, 2012 at 8:29 pm
    Hi Doug,
    Little button at top right of Sequence opens a drop down, deselect “Audio Time Units” if selected
    Jeff Pulera
    Safe Harbor Computers
  • John-michael Seng-wheeler
    November 16, 2012 at 11:32 pm
    Go to Project>Project Settings>General and then change Display Format from Frames to Timecode.
    JM
  • Doug Zimmerman
    November 17, 2012 at 2:23 am
    Jeff and John-Michael, thank you both for your responses.
    Toggling between Frames/Timecode in General Settings has no effect. I’ve also restarted, and created new sequences, to no effect.
    Toggling Show Audio Time Units in the Sequence drop-down switches it between raw frame numbers when it’s off (no min,sec,frames) and complicated numbers (00:06:47.874) when it’s on.
    All timelines in all panels are only showing a cumulative frame count, with no division into minutes and seconds. It’s probably the result of me accidentally hitting a wrong keyboard command or something . . .
    November 17, 2012 at 2:44 am
    Check Sequence > Sequence settings and change the display format there. The sequence’s Timecode display settings override the general.
  • Doug Zimmerman
    November 19, 2012 at 1:58 am
    Thank you. In my Sequence Settings, for Display Format, Frames is the only option. Why would this be?
    November 19, 2012 at 2:34 am
    That is very odd…. I shall do a little exploring.
    November 19, 2012 at 2:49 am
    Did a little digging. What is the Timebase is your sequence set to? When the Timebase is set to a non TV standard timebase (such as 10fps 12fps 14.71fps.. premiere supports anything,) “frames” is the only option.
    I’ve had cellphone videos with odd frame rates… what are you editing?
  • Doug Zimmerman
    November 19, 2012 at 3:04 am
    Ah, thank you. 10fps. Screen capture from a computer. So I’ll just have to deal with frame numbers up to infinity on this one. It gets output to 30fps at the end, so maybe I need to work in 30fps also. Thanks for your research, I really appreciate it!
  • Lubem Ajiva
    September 4, 2017 at 3:38 pm
    Thank you so much, reading this was so helpful. I was facing the same challenge but this came thru for me. God bless you. With love from Nigeria
