Activity › Forums › Apple Final Cut Pro Legacy › How to change timecode on quicktime source files?
Posted by Jay Cornelius on June 20, 2005 at 9:33 amAny idea of an app or util that easily changes the timecode on source files / clips?
Stanton Kellam replied 14 years, 7 months ago 5 Members · 4 Replies -
Jerry Hofmann
June 20, 2005 at 2:18 pmFCP can do this… look in the Modify menu… it’s there.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Steven Gonzales
June 20, 2005 at 5:24 pmIf you need to change a bunch of quicktimes, you can use the free utility Sebsky tools.
Export a batch list from final cut, bring that in to Cinema Tools, tag all those files with the timecode you want in cinema tools, make sure the Cinema Tools records have the right file names to match your quicktime files, then export an ALE (avid log exchange) file.
Then you can use Sebsky tools, point it to the folder full of quicktimes, point it to the ALE file with the files names and new timecode which you exported from Cinema tools, and batch it all.
https://www.dharmafilm.com/sebskytools/
Paul Carlin
September 11, 2010 at 5:09 amI realise this is an old thread, but here is a modern answer…
QtChange from VideoToolShed. $25
https://www.videotoolshed.com/product/42/qtchange
