Activity Forums Boris FX Particle Illusion How to change the default Libraries directory (path)?
  • How to change the default Libraries directory (path)?
    Posted by Luis Torres on June 4, 2015 at 11:13 am
    Hi folks, when checking for updates at “AutoUpdate” window, the “Libraries will be installed to:” isn’t the place I want to save them, so I wonder how do I get to change it?
    I tried the Manager (Ctrl+M), but it didn’t work. In the bottom middle window, it shows folders/paths that I don’t get to delete, I just get to add, but when adding a folder/path, it doesn’t change the “Libraries will be installed to:”
    Please, help. How do I change the path that shows in the dropdown list at “Libraries will be installed to:” in the AutoUpdate window?
    Francois Blawat replied 11 years, 3 months ago 2 Members · 1 Reply
  • Francois Blawat
    June 4, 2015 at 2:18 pm
    Luis,
    If you have that path, I would let the program download to that location, then you can manually copy the Emitters over to the path you want. You will need to make sure pi3 is closed out before you copy/move those .il3 files to the new location.
    Otherwise, I have never actually changed this path since it is related to where you installed pi3 originally.
    Best luck.
    FixitMad
