Activity › Forums › Apple Final Cut Pro › How to change the default audio fade curve
  • How to change the default audio fade curve
    Posted by Lisa Johnson on March 15, 2018 at 3:33 pm
    I know, I know, I need to update my version of FCPX….
    I am running 10.2.3. I would like to reset the default audio curve from +3 db to the S-curve. How in the world do you do this? Can you even do it? Can you do it in newer versions of FCPX?
    Lisa ????
    Gregor Queck replied 7 years, 2 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    March 15, 2018 at 8:59 pm
    Save the transition as a favorite and make it the default audio transition.
  • Doug Metz
    March 15, 2018 at 9:19 pm
    I think Lisa wants to alter the default behavior of the audio handles themselves, instead of having to right-click and select the preferred curve.
    Doug Metz
    Anode
  • Jeremy Garchow
    March 15, 2018 at 11:44 pm
    [Doug Metz] “I think Lisa wants to alter the default behavior of the audio handles themselves, instead of having to right-click and select the preferred curve.”
    Ah yes.
    If true, that is something that would make a great feature request.
  • Lisa Johnson
    March 16, 2018 at 2:29 am
    That’s exactly what I want to do!
  • Gregor Queck
    July 17, 2019 at 11:38 am
    Have you found any solution?
    ”Conversations don’t have to be easy to be worthwhile”
    Jordan Peterson
