Activity Forums Adobe After Effects Expressions How to change solid color using slider control ?
  • How to change solid color using slider control ?
    Posted by Mike Jones on July 22, 2014 at 1:53 pm
    Hello,
    I have a solid layer and I want to change its color using a slider control.
    example: (if value = 0, color = yellow //// if value = 1, color = red)
    I tried using the below expression that I found in this thread:
    slider = Math.floor(effect("Slider Control")("Slider").value);
    if (slider == 0)
    [.5,.5,.5,1] // medium grey
    else if (slider == 1)
    [0,1,0,1] // green
    else [1,0,0,1] // red
    but I am getting an error that the expression result must be of dimension 1, not 4.
    So how can I do this ?
    Tom Holmes replied 12 years, 2 months ago 3 Members · 2 Replies
  • Dan Ebberts
    July 22, 2014 at 4:14 pm
    You need to apply the expression to a color parameter, like that in the Fill effect.
    Dan
  • Tom Holmes
    July 24, 2014 at 4:29 pm
    Hey,
    Id add two colour controllers to the layer. set one colour to the yellow and the other to red and then write your if else statement but don’t write the 4 value array just pickwhip to the colour controllers.
    if(effect(“Slider Control”)(“Slider”)==0)effect(“Color Control” (“Color”)else if(effect(“Slider Control”)(“Slider”)==1)effect(“Color Control 2”)(“Color”)}
    hope this helps!
    Tom
