Activity Forums Adobe Premiere Pro How to change pan attributes of source audio clips?
  • How to change pan attributes of source audio clips?
    Posted by Chi-ho Lee on June 12, 2014 at 3:22 pm
    So I can’t seem to find the answer to this via the search or googling. Is there a way to change the pan of a source clip from the bin so it will carry this change with each subsequent edit?
    I would imagine this would be easy but I can’t figure it out….thanks for any advice!
    Chi-Ho Lee
    Film & Television Editor
    http://www.chiholee.com
    Adam Purcell replied 7 years, 6 months ago 5 Members · 5 Replies
  • Daniel Waldron
    June 13, 2014 at 12:16 pm
    You can right click the clip in the bin, go to “Modify” –> “Audio Channels.” This doesn’t really allow you to pan the audio, but it does allow you to map it to whatever channels you want.
  • Jon Doughtie
    June 13, 2014 at 1:22 pm
    And it is important to remember you need to make these changes BEFORE you place the clip in the timeline.
  • Chi-ho Lee
    June 13, 2014 at 2:44 pm
    I knew you can remap the audio channels but is there no way to change the pan of a source clip?
    Chi-Ho Lee
  • Paul Neumann
    June 13, 2014 at 5:51 pm
    Highlight the clip in the bin, right click, New Sequence From Clip, pan how you want. Use this sequence as a replacement for the clip and if you don’t like seeing a sequence in your timeline you can set it up to show as a clip (no renaming necessary) and the pan info will remain intact.
  • Adam Purcell
    March 8, 2019 at 9:14 pm
    The answer is apparently “No”, because this program was developed by monkeys.
    Seriously… I’d never use this program if I wasn’t forced to.
