Activity › Forums › Adobe Premiere Pro › how to change just a hand color and also send selected only to speed grade?
  • how to change just a hand color and also send selected only to speed grade?
    Posted by Kent Beeson on January 18, 2014 at 12:06 am
    Used to color correction and using secondary color correction in FCP7, so how to do in PP CC latest? I want to simply isolate a hand and change its color not effecting anything else…how?
    Also, I only want to have maybe 3 or 4 shots on timeline sent to speed grade – I tried in and out point then send to SG but it still loaded the entire 10 minute timeline…any way just to do only in/out or even lasso a few shots and send those only to SG?
    Kent Beeson replied 12 years, 8 months ago 3 Members · 5 Replies
  • Paul Neumann
    January 18, 2014 at 3:22 am
    Send the whole sequence and only correct those shots you want. It’ll be like you never left.
    As far as the hand, use a mask in speedgrade to just change the part you want.
  • Kent Beeson
    January 18, 2014 at 3:40 am
    you mean you can’t just lasso a few shots in pp cc and send to sg?
    So how in the world once in speed grade can you enlarge the time line to see specific shots
  • Morten
    January 20, 2014 at 10:05 pm
    There are “secret” keyboard shortcuts to most SG functions. Zoom in timeline uses Ctrl+Scrollwheel.
    Also numeric keypad +/-
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
  • Paul Neumann
    January 21, 2014 at 4:35 am
    You could put those few shots in a sequence of their own, send that short sequence to SG, do your grade, export the grade for each shot as a Look, then apply those Looks to your original shots on your original timeline.
    There’s more than a handful of ways to work with PPro and SG. Whatever’s most comfortable for you. But they’re all good.
  • Kent Beeson
    January 21, 2014 at 11:39 pm
    This sounds at least interesting and doable though shame it’s not a bit more intuitive to just lasso what you want in PP CC, send to SG, and your off…thanks for your help
