Activity Forums Adobe After Effects How to change Framerate for each Comp – Projectwide
  • How to change Framerate for each Comp – Projectwide
    Posted by Marc Nibor on October 20, 2012 at 4:46 pm
    I am working with a template which is set to NTSC. It consists of about 40 comps.
    Just curious… is there a way to change the framerate in the composition setting for ALL comps at once?
    I’d probably done by now if I hadn’t posted this… but it’s handy to know for future reference ; )
    Roland R. kahlenberg replied 13 years, 10 months ago 2 Members · 2 Replies
  • Marc Nibor
    October 20, 2012 at 6:20 pm
    Thank you Dave.
  • Roland R. kahlenberg
    October 21, 2012 at 1:34 am
    What you’ll want is the script, Selected_Comps_Changer.jsx. You can get it on this page – https://www.crgreen.com/aescripts/. Ensure that you first select the comps in the project panel. Then all you need to do is to type in the desired frame desired into the frame rate input box.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
