Activity Forums Adobe After Effects how to change default mask color?
  • how to change default mask color?
    Posted by John Adams on February 18, 2009 at 8:45 pm
    I’m pulling mattes from a mountain of greenscreen ftg and the default yellow masks are doing my head in.
    Is there a way of changing the default colour? I know it can be done in AE7 and prior via the prefs file but I’ve yet to find a solution for CS3 (8.0.2).
    I’ve tried nab’s cool little script — https://www.nabscripts.com/Forum/Scripts/myScripts/maskColorChanger.jsx — but it has no effect on my comps. Must be for AE7, I guess.
    Also tried the ‘cycle mask color’ switch in the preferences but it comes up with as many useless colours as useful — still forced into manually clicking color swatch then sliding the colour selector, then clicking ok… too much clicking to solve something that should be definable by the user in the first place. Adobe, hear my pain!
    Your words of wisdom are appreciated. Cheers.
    Rugged yet hygienic.
    Yossi Siegel replied 3 years, 6 months ago 4 Members · 5 Replies
  • John Adams
    February 19, 2009 at 12:31 am
    Ahh.. so are the mask colours tied to the label colours in the preferences? (I’d check right now but AE is locked up rendering)
    Sneaky, that…
    Cool, I’ll give it a go, Dave.
    My retinas extend their utmost gratitude to you.
  • Filip Vandueren
    February 19, 2009 at 1:03 am
    In the After Effects 9.0 prefs file there are these lines, for your editing pleasure:
    ["Mask Colors"]
    "Cycle Label Colors" = 00
    "Default Color (0xAARRGGBB)" = "00ffff00"
    "Interpolated Mask Dim Factor" = "0.750000"
  • Pentti Kakkori
    February 19, 2009 at 7:23 am
    Or simply click that little yellow square and change the color what ever you want.
    Sorry I didn’t read the first post to the end.
    Maybe the quantel red as a default color would be better.
    But anyhow I’ve found it very useful and quick way to separate different bodyparts when rotoscoping, just select different saturated colors to every mask
  • John Adams
    February 19, 2009 at 1:09 pm
    I see says the blind man…. I was looking at the wrong prefs file. I checked the file com.adobe.AfterEffects.plist in the root of the Preferences directory (Mac OSX) and I had no joy. But, Filip, your post got me thinking I must be missing something, and I was.
    If anyone else is a numpty like me, then follow the path below and you’ll find the proper prefs file:
    ~/Library/Preferences/Adobe/After Effects/Adobe After Effects 8.0 Prefs
    That’s where this kernel of joy is hiding:
    [“Mask Colors”]
    “Cycle Label Colors” = 01
    “Default Color (0xAARRGGBB)” = “00ffff00”
    “Interpolated Mask Dim Factor” = “0.750000”
    Ok, I’m off to go hide in a dark corner now.
    Cheers all for your help.
  • Yossi Siegel
    February 22, 2023 at 4:10 pm
    Thank you!
    I was getting confused with THAT color and the actual FILL color I have within the mask…
