Activity Forums Adobe Premiere Pro How to change color in “dip to white” transition
  • How to change color in “dip to white” transition
    Posted by Taya Taya on July 17, 2014 at 10:39 am
    I am working with premiere pro cc, and would like to know if there is a way to change the color of dip to white video transition from white to beige. I really like this “dip to…” transition and totally suits my needs, but the white (or black) color is too flashy for my needs. I think changing the color would make the transition much more smoother, but still obvious there is a transition… I hope I make sense 🙂
    Some preset transitions have an option to change the color, but not dip to white. Is there any other way (besides a simple color picker) to change the color?
    Any advice, (very) similar alternative to dip to white or any other alternative (besides programming:)) would be appreciated.
    Thank you in advance!
    Taya
    Taya Taya replied 12 years, 1 month ago 2 Members · 2 Replies
  • Anna Wysocka
    July 31, 2014 at 8:16 pm
    Hi Taya,
    I had a similar problem and from this what I know, you have to create a matte in desired colour and then put cross dissolve at the beginning and the end.
    I know that it is just walking around the problem.
    Perhaps with next update Adobe will add function that allow to dip to (any) colour.
    Anna
  • Taya Taya
    August 1, 2014 at 5:35 am
    Hey Anna, I came to the same solution, and it works pretty fine..yes, dip to any colour would be usefu, until then …
