Activity › Forums › Apple Final Cut Pro Legacy › How to change audio capture settings in batch list
  • How to change audio capture settings in batch list
    Posted by Itamar Kool on May 14, 2006 at 3:50 pm
    I let someone create a batch list. Now there was no audio settings in it. When I imoprted it, the setting of the audio was 1 mono. How can I change that, once the batch list has been imported into FCP??
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.3.9/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 6.5 Pro
    http://www.koolendeanderen.nl
    Bret Williams replied 20 years, 4 months ago 3 Members · 2 Replies
  • Find the columns in the Browser with the settings that you want to change and “control-click” (right mouse button) to see a menu to change them (if you select ALL of them, you can change them all at once.)
  • Bret Williams
    May 14, 2006 at 11:05 pm
    That’s broken. The clips have to be offline – but however in version 5 it’s quit working. I can no longer make changes to the audio or track columns. It should be the audio column that you change.
