Activity › Forums › Apple Final Cut Pro Legacy › how to capture HDV?
  • how to capture HDV?
    Posted by Teabgs on November 7, 2005 at 6:59 pm
    Hey everyone. here’s my problem: I’m trying to import some HDV footage from a Sony HVR-Z1U camera and it isnt being recognized in FCP. I also tried with a Sony CMOS but it doesnt show up either. I’ve tried changing the settings in FCP for capturing but nothing seems to work. I cant even get picture to show up with it set to non-controllable device. This is FCP 5.0.1 if it matters and on a dual 2Ghz G5. If anyone has anything to suggest that I try please let me know.
    Thank you so much!
    Jason
    Jon Boffa replied 20 years, 9 months ago 4 Members · 4 Replies
  • Michael Bugera
    November 7, 2005 at 9:42 pm
    I just went though my first capture today and had problems until I made sure the HDV settings were chosen in the Easy Setup menu. Then it worked fine.
    I hope that’s the answer for you.
    Oh, the camera I’m diging from is the HDR-FX1.
    Bugsy
  • Kevin Monahan
    November 7, 2005 at 9:58 pm
    You are right Bugsy. The Easy Setup for HDV 1080i makes the process a no-brainer.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Teabgs
    November 7, 2005 at 10:51 pm
    Thanks for the replies. You are right, the easy setup makes it easy, although after that didn’t work I posted here. It turned out to be the AJA box connected to the G5… should have thought not to try having both connected at the same time, but I just didn’t think about it. Would have saved a few hours too, oh well. Batch capturing as I type. Thanks!
  • Jon Boffa
    December 12, 2005 at 7:38 pm
    Bugsy,
    Just bought an HDR-FX1 along with new Apple FCP Studio system.
    Am curious about how others are using such equipment. Since I ran out of dough for a HDV deck, I plan on hooking the FX1 directly to the G5, and capture direct. Is this how you’re doing it now?
    I’ve heard this is not a recommended approach as the footage recorded on the camera directly is too compressed and you lose too much to output a high-quality finished product.
    Any feedback would be greatly appreciated.
    JB
