Activity › Forums › Adobe Premiere Pro › How to capture aux audio (ch3 &ch4)?
  • How to capture aux audio (ch3 &ch4)?
    Posted by Mike Carro on December 6, 2005 at 4:04 pm
    I’m using a Canon XL1s and have some audio on channel 3 and 4. Can’t seem to be able to capture this via firewire. Is there a setting or what?
    thanks
    Aanarav Sareen replied 20 years, 9 months ago 4 Members · 4 Replies
  • Tim Kurkoski
    December 6, 2005 at 5:38 pm
    Premiere doesn’t capture the second stereo pair at all. You’ll either need to use another application, or change the audio mix settings on the camera and capture the audio in a second pass. (If I recall, I once looked up how to do that with an XL1 and wasn’t able to find a way, so you’ll probably need to use another app. Try Scenalyzer.)
  • Mike Carro
    December 6, 2005 at 7:54 pm
    yeah, I tried changing the settings on the camera but to no avail. You’d think there would be a way. Never heard of Scenalyzer but I’ll give it a try.
  • Eric Jurgenson
    December 6, 2005 at 8:18 pm
    The Matrox RTX cards allow you to capture video and all four audio tracks at once in Premiere.
  • Aanarav Sareen
    December 7, 2005 at 7:07 am
    Yes, ScLive will capture the third and fourth channels.
    Apart from that, it is a great capturing utility. It can easily capture from various sources too!
