Activity › Forums › VEGAS Pro › How to capture a 720×480 still not a 655
  • How to capture a 720×480 still not a 655
    Posted by Larry Watts on June 8, 2007 at 9:01 pm
    I’ve always worked around this, but need to capture a DV clip still in a true 720 x 480 pixel image. I always get a 655 x 480
    How do I?
    Larry
    Edward Troxel replied 19 years, 3 months ago 4 Members · 3 Replies
  • Gary Kleiner
    June 8, 2007 at 10:47 pm
    Still capture resolution is determined by the preview resolution. Set to Best/Full and you will get full res. Temporarily chging the project to progressive (nt interlaced) will improved the capture as well.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Mike Kujbida
    June 9, 2007 at 12:32 am
    655 x 480 is the max still res that you can get out of Vegas on a standard definition project 🙁
    I’ve forgotten the rationale but it has something to do with the aspect ratio issue.
    A possible workaround would be to bring the video into another app (MediaPlayer Classic??)and try it there.
  • Edward Troxel
    June 9, 2007 at 2:16 am
    While you typically don’t want to do this, there IS a way to get the full number of pixels. Beside the “Save Snapshot” button is another button that will “Copy to Clipboard”. Copy to the clipboard, open your paint program, and paste the image to a new document. That will give you the full 720×480 in your paint program. However, that doesn’t take into account the difference between square and non-square pixels.
    Edward Troxel
    JETDV Scripts
