Activity Forums Adobe Premiere Pro how to calibrate TV and monitor…
  • how to calibrate TV and monitor…
    Posted by Chip Douglas on September 3, 2005 at 12:49 pm
    I’ve got a matrox rt 100 pro card with my good old phillips 14″ tv hooked up and a 19″ crt no name monitor to the computer. How do i get the tv and the monitor calibrated so that i get the right brightness/contrast and the right color in premiere pro.
    I’m making a dvd-project and I would be crying if it turn out to look wrong on another tv.
    Regards, Chip
    Gurnsey replied 21 years ago 2 Members · 1 Reply
  • Gurnsey
    September 6, 2005 at 4:43 am
    Put color bars in your sequence and park the cursor over them. I think they’re under the “file” menu. Paste this in your web browser and off you go…
    https://www.videouniversity.com/tvbars2.htm
    Concentrate on the TV since that’s where your stuff is bound for anyway. Plus, it’s a better picture than the monitor. Once you get the TV set up, leave it alone and just check it once in a while. For the computer monitor the best thing is just to do an eyeball comparison to the TV and use the monitor’s panel controls for adjustment. You can also use your graphics card control panel to tweak the monitor. This is down and dirty but without scopes it’s your best bet. You have to trust your setup, though. If it looks dark in the TV, don’t adjust the TV!
    It would really help you to familiarize yourself with PP’s built-in scopes — they’re good. While your cursor is parked over the bars you could check out how they look in your PP program monitor with different scopes. Choose them with the pull-down menu at the top of the monitor. Do a help search for items such as: waveform monitor, vectorscope, color bars, black level, setup. There’s lots of web info, too, and some very thick textbooks on SMPTE color bars and calibration theory. If none of this helps and your footage is green on your aunt’s television, tell her to buy a new TV.
