Activity › Forums › Adobe Encore DVD › how to burn sd project to blu-ray in maximum quality?
  • how to burn sd project to blu-ray in maximum quality?
    Posted by Peter Clovelly on December 28, 2010 at 5:35 am
    I have a standard definition DV project (PAL 720×576 50i) that I plan to burn to DVD. However I have a blu-ray burner in my computer so I was wondering if I could also burn my project to a blu-ray disk with higher quality, ie less compression, due to blu-ray’s greater capacity? Or possibly no additional compression at all? I am using CS5 Master Collection so I have access to After Effects if needed.
    Peter
    Peter Clovelly replied 15 years, 7 months ago 2 Members · 3 Replies
  • Chaddix Malchow
    February 26, 2011 at 9:52 pm
    you can, when exporting out of adobe premeire,which im assuming youre using, select mpeg2 – blu ray, and under resolution, theres an SD option for 720×480 in NTSC, so just make it PAL, boost the bitrate, throw it in encore and you’re good to go
  • Peter Clovelly
    February 27, 2011 at 10:00 am
    Thanks Chaddix – I hadn’t seen that setting, so I’ll check it out.
  • Peter Clovelly
    February 27, 2011 at 1:23 pm
    OK that worked well. My test footage was only 6 min long so I maxed out the encoding settings: CBR 40 Mbps, M frames 2, N frames 8. Played nicely in my Blu-Ray player.
    Thanks again.
