Activity Forums Apple Final Cut Pro How to burn a PAL DVD with 1920 x 1080 60i AVCHD footage?
  • How to burn a PAL DVD with 1920 x 1080 60i AVCHD footage?
    Posted by Bill Tsolakidis on October 2, 2011 at 6:48 pm
    So friends and fellows. What would be the best way to produce a PAL DVD, edited through FCPX, with 1920×1080 601 AVCHD media?
    Thanks for all your help in advance.
    Bill Tsolakidis
    John Pale replied 14 years, 11 months ago 4 Members · 3 Replies
  • Dave Brandt
    October 2, 2011 at 8:34 pm
    I have done this successfully the other way round, ie from 1080 50i pal to NTSC DVD.
    For you, i think the best way would be to send to compressor and choose dvd preset, then modify the preset so your video format is PAL and frames are 25.
    Audio is the same for both formats, ie AC3
    Good luck
    Dave
    https://www.inputmedia.ie
  • Andy Mees
    October 3, 2011 at 1:19 am
    Appreciate its not directly answering your question Bill, but you might want to suggest / offer up a regular NTSC DVD for refusal first … pretty much most (all?) PAL DVD players will work with that just fine. Certainly in my PAL neck of the woods I can’t remember the last time I saw TV, DVD Player etc that wasn’t multisystem.
  • John Pale
    October 3, 2011 at 3:20 am
    You can’t do it all in one step.
    Send your timeline to Compressor and create a 1080i 50 ProRes version of it.
    Turn on the Frame Controls and set the rate conversion to Best.
    Take the resulting file and select an appropriate DVD preset, which will downconvert and make a PAL MPEG2 file and also an AC3 file for your audio.
