Activity Forums Adobe After Effects how to break mask nodes
  • how to break mask nodes
    Posted by Sohailfx on August 2, 2005 at 10:04 am
    hello there…
    i have been working on different mask, in after effects layers..
    some times i want to break mask nodes, to make some critcle curves…
    for example, i draw a circle on blank layer, and need to break the circle’s quarter arc,
    and in so many other curves, some times, i need to modify few curves by breaking the nodes, like what we do in coral, illustrator..
    now i need to know, how can we do this..
    hope u scholars, understand my problem, i would be very glad if somebody can guide me to solve this problem….
    thanks
    sohailfx
    Daniel Visionize replied 11 years ago 4 Members · 3 Replies
  • Steve Roberts
    August 2, 2005 at 10:47 am
    If I recall … you select the segment of the mask between two points, then click on layer>mask>closed up there in the menu bar. That should remove the segment you just clicked.
    The switch goes either way: to open or close a mask.
    Steve
  • Vasilis Kaminaris
    September 13, 2013 at 11:00 pm
    I have the same question but 8 years later. In AE cs6 there isn’t any “closed up” option under layer/mask.
    How can i break let’s say 1 node in a 4 nodes circle mask in a shape layer?
  • Daniel Visionize
    September 3, 2015 at 12:21 am
    To close or open a path:
    Select the 2 points from the path where you want the path to break open. Then go to “Layer” – “Mask & Shape path” – “Closed”.
