How to boost volume?
Posted by Ken Bennett on September 3, 2010 at 12:42 amI’ve got a few clips where the original recorded volume is VERY low. I’ve got the track volume maxed out. The volume of the clip is maxed out as well. How can I further boost the audio in this clip without effecting the other volume levels of the project?
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!John Rofrano replied 16 years ago 6 Members · 9 Replies -
Danny Hays
September 3, 2010 at 1:53 amA compressor plugin will do it. You can raise the quiet parts and not the louder parts.
There’s aready one by default in each audio track in Sony Vegas. Try the 4:1 – 10:1 presets and let us know what you think. -
Ken Bennett
September 3, 2010 at 2:03 amThat did the trick. Thanks.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures! -
John Rofrano
September 3, 2010 at 2:33 amYou also might want to normalize the clips. Right-click the audio event and select Switches | Normalize. This will bring the volume up without having to use the compressor. Then you can use the compressor to make it even louder if needed.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Stephen Mann
September 3, 2010 at 5:43 amI use the free program: Levelator.
It was written for podcasters, but it is like magic on dialogue files.
Steve Mann
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Gilles Gagnon
September 3, 2010 at 12:41 pmThanks for the tip on Levelator Steve. From what I see it only comes as an external pgm and not a plugin?
I’ll give it a try as I often could use it for recorded interviews.
Gilles -
Stephen Mann
September 3, 2010 at 1:57 pmYou just render your best audio from vegas to a wav file, drop it onto Levelator, then bring the resulting file back into Vegas.
Steve Mann
Roger Bansemer
September 4, 2010 at 1:17 pmI tried this out but it’s really bringing up the quiet passages to the audio which defeats the purpose for me. I’d love to have something smooth out my audio when I for instance turn my head away from the mike. Any more thoughts on this?
John Rofrano
September 4, 2010 at 3:24 pmLevelator does what you would have to do manually to smooth out the volume. If Levalator doesn’t do a good job, then manually adjusting is the only other choice. When your head moves off axis from the mic, you not only get a drop in volume but a change in tonal characteristics. Lavalator will only increase the volume but it will not match the tone. You would have to do that manually.
~jr
