Activity Forums Maxon Cinema 4D How to blend two objects (Metaball-similar)
  • How to blend two objects (Metaball-similar)
    Posted by Brian Murphy on September 24, 2009 at 6:29 pm
    I’m trying to put two objects next to one another and have a metaball effect to connect the two. Metaballs requires a lot of points and works better on spherical objects. I just want to take the end of a long object and have it connect/blend with the end of another long object as I don’t want to model the connection between the two – possible?
    Brian
    Brian Murphy replied 16 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 24, 2009 at 11:09 pm
    No way to do it automatically, but it’s not really that difficult to model. Just connect the objects (connect command), then select the polys you want to connect on each one and use the bridge tool to connect them.
  • Brian Murphy
    September 24, 2009 at 11:34 pm
    Thanks, Adam.
    Brian
