Activity Forums Adobe After Effects How to blend Keyframes? (i don’t mean normal interpolation)
  • How to blend Keyframes? (i don’t mean normal interpolation)
    Posted by Selva Malakia on March 13, 2017 at 6:32 am
    I’m looking for a plugin/expression that can blend a set of keyframes.
    For instance:
    1. I’ve an animated walk cycle of a character.
    2. And an animated run cycle of the same character.
    How to blend 1 and 2 so the character can walk and gradually run. Is there any sophisticated workflow out there?
    Cassius Marques replied 9 years, 6 months ago 2 Members · 1 Reply
  • Cassius Marques
    March 13, 2017 at 8:05 pm
    You can add to any property a linear expression essentially transitioning between two values (lets say add the expression to the foot target of the run cycle and use the foot target of the walk cycle as a argument) . But that won’t solve your problem. A walk cycle and a run cycle have both very distinct behaviours. A run cycle has a pose in which no feet touches the ground. Transitioning from a walk cycle would mean that the character would slightly hover over the ground when on those moments.
    In my opinion you can’t automate that and make it look fine.
    Cassius Marques
    http://www.zapfilmes.com
