Activity › Forums › Adobe After Effects › How to “bend” the side of a “cube”?
  • Michael Szalapski
    March 20, 2018 at 3:11 am
    Can you share an example that doesn’t involve downloading a zip file?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Mark Whitney
    March 20, 2018 at 3:45 am
    That’s not really bending but rather just simple parenting of layers to one anothers edge. Do some research on building a 3D box or room in AE.
  • Richard Garabedain
    March 20, 2018 at 8:25 pm
    nothing is bending…a 2.5 d layer is rotating. the whole image is an optical illusion with the alpha channel being the only part that is being animated
  • Steve Bentley
    March 20, 2018 at 9:35 pm
    You can also use the transform effect and take advantage of the skew feature. Trying to do this in AE’s “3d” world will not get you there because there is no perspective here. The example you sent is isometric so all “perspective” lines are parallel.
