Activity Forums Adobe After Effects how to bend picture into arc?
  • how to bend picture into arc?
    Posted by Peter Lee-jones on March 8, 2009 at 10:34 pm
    Hi CC AAE,
    How do i curve a picture so that it becomes an arc? I am trying to bend four long rectangular pictures to make a donut shape.
    thanks Pete
    Pinewood Studios, UK
    Peter Lee-jones replied 17 years, 5 months ago 2 Members · 2 Replies
  • Filip Vandueren
    March 8, 2009 at 11:40 pm
    Several ways to do it.
    Distort -> Warp
    has an ‘arc’ setting that warps the layer to half a donut, so first you should precomp the images together 2 by 2.
    This is the easiest to set up I think.
    Distort -> Polar Coordinates
    set to ‘Rect to Polar’ warps a layer to a 360° circle, But then you’d have to precompose the 4 images side by side, + this effect renders a quite small circle as the endresult.
    Distort -> CC Bend It
    set the Start at the left side of the layer, and the End at the right side of the layer.
    Use a Bend setting of 50.
    This will give you your true 90° donut quarter.
    But it only draws within layer boundaries, so you’ll nee a Utility->Grow Bounds Effect placed first on each layer.
  • Peter Lee-jones
    March 9, 2009 at 9:05 am
    that was easy! thanks for your help
