Activity Forums Adobe After Effects Expressions How to batch horizontal center 300 titles in premiere?
  • How to batch horizontal center 300 titles in premiere?
    Posted by Ollie Brent on July 26, 2017 at 10:36 pm
    Sorry if this is the wrong place for this, but someone suggested I cross post here.
    So I have a piece with 300 subtitles that came in via an XML and the horizontal position is different on all of them. There’s a handful that are perfectly centered but most are either too far left or right. Right now the only fix I can find is going into every single title and manually hitting the horizontal center button on all of them… obviously this is not an ideal solution and I’m trying to find a better fix since this problem happens pretty often. I’ve been looking for a solution for an entire day and I can’t find anything that’ll do the job. Is there some sort of plugin or downloadable effect that has a horizontal center option that I can paste attributes on all the titles? Or some sort of script/expression that can accomplish this?
    Ollie Brent replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
