Activity Forums VEGAS Pro How to Avoid this ??
  • How to Avoid this ??
    Posted by Accountclosed on August 16, 2007 at 11:59 am
    am from Pakistan so in pakistan we use PAL setting for non-linear.
    in vegas 7 i used everything for my project setting like i use PAL output Best and stuff but look whenever i render my project its cutting edges from rendered file..
    not in computer but on TV or in DV or DVD or CD player its cutting edges even whole out of save areas ??
    look at this
    its an image when i paused same file running on windows and on out put TV
    https://img231.imageshack.us/img231/6826/11sw6.jpg
    closer its Monitor that played in windows
    https://img403.imageshack.us/img403/9050/31zr2.jpg
    and its DVD or DV or CD player on TV
    https://img403.imageshack.us/img403/1108/41si3.jpg
    so how can i avoid these cutting edges on TV
    hope you understand
    for final time “when i render file its perfect in windows but whenever i write it on DVD , DV or CD when its played on TV its cutting Edges even 10% of the Screen area..
    Douglas Spotted eagle replied 19 years ago 4 Members · 5 Replies
  • Randall Raymond
    August 16, 2007 at 2:17 pm
    You need to turn on your ‘safe area’ markers in preview and create titles within that area and with enough border around them to look professional
  • Terry Esslinger
    August 16, 2007 at 2:56 pm
    You have run into the OVERSCAN problem that occurs to one degree or another on all tvs – but not on pc monitors. If you play it back on some lcd or plasma tvs you might find that the overscan is less. Usually it is greater on crt tvs.
    That is the reason for the ‘safe’ area dotted boxes you can turn on and off in the preview window. Another way is to use a tv hooked up to your NLE while you are editing to actually see what it will look like (at least oon that tv).
  • Accountclosed
    August 16, 2007 at 8:17 pm
    thanks for reply
    yea i have Attatched a TV with my NLE so thats why i gave PIC 😉
    umm is there anyway to work always in safe areas (yea i know what they are and how to use in vegas) but i wanted that is there any way that i have don’t have to stretch and squeeze titles and backgrounds for same areas boxes.. when i drag and drop or use metrial they should FIT perfect safe areas ?
    i use Premiere Pro 2 and there’s not any kinda problem like this why with Vegas ?
  • Randall Raymond
    August 17, 2007 at 3:01 am
    Well, my friend, you have to tell each title if it is widescreen or 4×3 in relation to your project settings.
  • Douglas Spotted eagle
    August 17, 2007 at 3:06 am
    use Premiere Pro 2 and there’s not any kinda problem like this why with Vegas ? All NLE preview screens have safe area indicators for this very reason. Including Premiere.
    In Vegas, generated titles will *always* fit the aspect of the project, but if you mix widescreen title graphics in a 4:3 project, you’ll likely experience some cut off.
    If you enable the Safe Areas overlay, you’ll always know where your titles lie.
    Douglas Spotted Eagle
    VASST
    Aerial Camera/Instructor
    Certified Sony Vegas Trainer
