Activity › Forums › Apple Final Cut Pro Legacy › How to avoid fuzzy/ugly lines on text/credits ?
Posted by Monkchild on December 11, 2005 at 12:36 pmHello.
Is it possible to get rid of those ugly/fuzzy lines that appear on all text (despite using thick fonts, a bit of shadowing, etc.) that you insert in your video project? There must be a way to make professional looking motion graphics for monitors, I mean, all the ones on the web (the trailers for movies for example) look fine…
Manuel F. rugeles replied 20 years, 9 months ago 5 Members · 5 Replies -
Walter Biscardi
December 11, 2005 at 12:40 pmAre you editing in an uncompressed timeline?
Do you have the Video Processing set to “Best?”
Those are two ways to enahance your credits.
Also, on the web, everything is progressive so the credits will always look better in progressive than interlaced.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow editing “Good Eats” in HD for the Food Network
Todd Reid
December 11, 2005 at 5:22 pmMake sure the “center” of your fonts are on even & whole numbers.
In the viewer window/motion tab, check your “center” settings. If they are not whole and even numbers, make them such and it may fix your problem.
example 11.67 is not a whole & even number, but 12 is.I have run into the same thing with nested compositions, weird but true!
Walter Biscardi
December 11, 2005 at 7:08 pm[todd reid] “In the viewer window/motion tab, check your “center” settings. If they are not whole and even numbers, make them such and it may fix your problem.
example 11.67 is not a whole & even number, but 12 is.”Especially the vertical setting, which I think is the second number. The horizontal is not so important, but vertical is very important.
Another tip, use the Boris 3D Text tool and not the FCP Text Tool. It’s a vector based tool and gives much cleaner results.
Kevin Monahan
December 11, 2005 at 8:42 pmAvoid moving around the wireframes to place text. Use the point controls in the Controls Tab, not Center in the Motion Tab or the wireframe.
Use Title 3D.
Don’t use pure white. Take down brightness to less than 90.
Avoid a solid black background.Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com
