Activity › Forums › Adobe Premiere Pro › How to avoid fuzzy/ugly lines on credits/text?
  • How to avoid fuzzy/ugly lines on credits/text?
    Posted by Monkchild on December 11, 2005 at 12:33 pm
    Hello.
    Is it possible to get rid of those ugly/fuzzy lines that appear on all text (despite using thick fonts, a bit of shadowing, etc.) that you insert in your video project? There must be a way to make professional looking motion graphics for monitors, I mean, all the ones on the web (the trailers for movies for example) look fine…
    Mark Weaver replied 20 years, 9 months ago 3 Members · 2 Replies
  • Aanarav Sareen
    December 12, 2005 at 7:34 am
    If you have AE take a look at its text engine. If not, there is an article on the Cow on how to use titles properly.
  • Mark Weaver
    December 12, 2005 at 5:43 pm
    The biggest problem with text is interlaced video. Depending
    on the placement, size and/or movement text will flicker or
    look a little fuzzy. I’ve found that PPro 1.5 is aweful at
    moving text because there is no pixel per second(velocity)
    control. AE is great, but you don’t have the titler so Photoshop
    needs to be used to create the cool text. I can’t remember
    the formula exactly, but I think it is:
    The speed of the text must be an even multiple of the field
    rate. Of course for NTSC this means that text moves really fast.
    My solution has been to live with a little blur and move the
    text at a rate of 1*field rate.
    The meyer’s book (volume 2) has a good section on this.
    Mark
