Activity Forums VEGAS Pro How to avoid fading when splitting? – Sony Vegas 12
  • How to avoid fading when splitting? – Sony Vegas 12
    Posted by Sergiu Ovi on October 25, 2014 at 10:16 am
    I am a little bit embarassed, it is possible I am wrong, but when I triend to split a video track in Sony, the audio track attached to the video did NOT get faded.
    Now, if I try and split a video, the audio track get a fade end/fade start.
    Is there a chance to skip the fading?
    Thank you.
    Jorma Nippala replied 11 years, 10 months ago 3 Members · 5 Replies
  • Jorma Nippala
    October 25, 2014 at 12:25 pm
    Uncheck the “Quickfade Audio Edits” under “Options.”
    Existing fades are not removed.
    Read the thread below though
    https://forums.creativecow.net/thread/24/953885
  • Sergiu Ovi
    October 25, 2014 at 12:34 pm
    Thank you very much, Jorma Nippala!
    After unchecking that, the fade is not present anymore.
    That solved my problem.
  • John Rofrano
    October 28, 2014 at 10:37 am
    [Sergiu Ovi] “That solved my problem.”
    Actually it caused a new one. The reason that Quickfade Audio Edits is on by default is to avoid your audio from clicking when you make a split! The click is caused by audio wave forms not matching up which can cause a “click” or “tick” in the sound. You never want to disable Quickfade Audio Edits unless you are specifically compensating for this in another way (e.g., manually crossfading). Video doesn’t have this problem which is why it’s not faded.
    I would strongly recommend that you NOT disable Quickfade Audio Edits unless you are compensating in some other way. If you start hearing ticks or click in your audio edits at least now you’ll know why. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sergiu Ovi
    October 28, 2014 at 1:15 pm
    Wow, thank your for the update.
    I will not use the original audio track. I will use another audio track for the clips I have splited.
    Thank you very much for clarifying this!
  • Jorma Nippala
    October 28, 2014 at 2:17 pm
    The CC thread I recommended in my post did mention the issue John Rofrano warns of.
