Activity › Forums › Boris FX › How to avoid “crawly” edged text
  • How to avoid “crawly” edged text
    Posted by Steve Pankow on February 24, 2009 at 8:07 pm
    Any tips for keeping the edges of fonts from getting “crawly” looking as they increase in scale? I have motion blur on, but the scale adjust is slow so it doesn’t appear to help out. Do I have to resort to putting a small blur on the entire comp?
    Peter Mcauley replied 17 years, 7 months ago 2 Members · 3 Replies
  • Peter Mcauley
    February 25, 2009 at 1:46 pm
    Hi Steve,
    Do you have the 1:2:1 deflicker function enabled in the project settings dialogue box? I would also suggest that you enable the “better quality field rendering” option, which is also located in the project settings window.
    I hope this helps.
    Cheers,
    Peter.
  • Steve Pankow
    February 26, 2009 at 4:09 pm
    Yes, those are always left on as the result without them would be even worse.
    These are rendered out with Animation codec – is there a better one out there for Avid that preserves “resolution” better?
    I’m bringing them in at 3:1. I’ve never noticed much difference with 2:1 and we rarely do uncompressed work here.
  • Peter Mcauley
    March 2, 2009 at 1:07 pm
    Hi Steve,
    Have you tried adding some motion blur to the piece to see if that helps to eliminate the staggered movement that you are seeing?
    Cheers,
    Peter.
