How to Automatically cross fade audio
Posted by Kyle Le on February 23, 2020 at 1:21 pmHi. I see that in the options drop down there is a place to select automatic crossfades. However, what if I don’t want the video clip to crossfade, but I just want the audio. Is there a way to do this since it would be very helpful for vlogging edits ? thank you
Wayne Waag replied 6 years, 6 months ago 4 Members · 3 Replies -
Francois Pénzes
February 23, 2020 at 9:49 pmHi Kyle
If you want your audio to keep matching the video, I only know one way. First, I put markers at every cut points then ungroup the video from the audio (U). I use the Split command (S) at the marker points. Give yourself some room between chosen clips. Making sure that only the video track is selected, I backtrack the video by 1 second (you don’t have to be picky about this). Group that section (G). After the audio fade-in mix is to my liking, I merge the video part accordingly If one does this for each clip, you then have total control, to the frame, on you clip.
If someone else has a better way, I would be happy to know about it. So far, it has served me well.
Cheers !
PC Win 10 Pro 64-bit 16gb
Ryzen 9 3900X 12 Core 4.60GHz
Radeon RX 5700 XT
Cameras: Canon XF305 + Canon XH-A1
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Dimitrios Papadimitriou
February 24, 2020 at 1:12 am -
Wayne Waag
February 25, 2020 at 6:10 pm“If someone else has a better way, I would be happy to know about it.”
Not necessarily better, but certainly easier. Here’s a demo of a very simple Happy Otter free tool that does this.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
It can be freely downloaded at https://tools4vegas.com/library/
wwaag
