Activity Forums VEGAS Pro How to Auto Space Events on a Track?
  • How to Auto Space Events on a Track?
    Posted by Scott Bruffey on August 12, 2013 at 4:34 pm
    There’s probably an easy way to set this but I can’t find out where to make the change.
    I’m looking for a way to set the gap between events so when I drop in a number of events on a track, Vegas will automatically space them out. When it comes time to render I then need only run the Set Region Script, do a batch render and I’m finished.
    For now, I need to turn on ripple and manually move every clip over and create a gap that way.
    Any suggestions?
    Scott Bruffey replied 13 years, 1 month ago 2 Members · 2 Replies
  • Matt Carlson
    August 12, 2013 at 10:45 pm
    There is not actually a native way to do this. Vegas scripting is how we are expected to get things done… so here is a script.
    using System;
    using Sony.Vegas;
    public class EntryPoint
    public void FromVegas(Vegas vegas)
    int GAP = 20;
    foreach (Track track in vegas.Project.Tracks)
    TrackEvent Last = null;
    foreach (TrackEvent ev in track.Events)
    if (ev.Selected)
    if (Last == null)
    Last = ev;
    continue;
    ev.Start = Last.End + Timecode.FromFrames(GAP);
    Last = ev;
    This does not provide for any contingencies (like audio events not being the same size or position as the corresponding video events, etc.) It will make a 20 frame gap for all selected events on a per track basis. Change the GAP variable to whatever you prefer and select everything you want to move including any audio tracks. If you need a more comprehensive approach that deals with Groups or any other anomalies let me know.
  • Scott Bruffey
    August 12, 2013 at 10:48 pm
    That’s so awesome!! Thank you!
