how to apply video fx to less that full chapter?
Posted by Doyal Gudgel on January 2, 2012 at 8:21 pmWhen a full chapter does not need editing in FX how to I mark off just a portion? I don’t usually want to create another chapter.
Thanks in advanceDoyal Gudgel replied 14 years, 8 months ago 2 Members · 6 Replies -
Mike Kujbida
January 2, 2012 at 8:24 pmSplit the event (use the ‘s’ key to do this) at the appropriate spots and apply the FX to that portion only.
Doyal Gudgel
January 2, 2012 at 8:30 pmI thought there might be another way. That creates another chapter. Still OK. I’m lazy I guess
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.com -
Mike Kujbida
January 2, 2012 at 8:59 pmAfter you’re done, group everything together so that it moves as a single event.
” That creates another chapter.”
You need to get your terms correct or you’re going to run into trouble doing a search in the manual or the online help file.
A chapter is a designated section on the timeline (it could be a single event or multiple ones) separated by markers and is used by DVD Architect. -
Doyal Gudgel
January 2, 2012 at 9:05 pmYes you are right. I forgot. I should have said another event
Hope to see you
Mike Kujbida
January 2, 2012 at 9:07 pm“I thought there might be another way”
There is and it’s called keyframing which can be a bit of a pain on a long event that you only want to have a small section affected.
Trust me when I say that the method I described is a LOT easier. -
Doyal Gudgel
January 2, 2012 at 9:10 pmIt’s complicated enough
Hope to see you
