Activity Forums Adobe After Effects how to apply tracking to a mask
  • how to apply tracking to a mask
    Posted by Cow_fan on February 8, 2007 at 9:30 am
    I created a mask over a moving object in my video clip using the pen tool. What I’d like to do is to track the moving object (using the built-in motion tracker) and apply it to the mask. I’d like the mask to precisely follow the object as it moves but I don’t want to make the adjustment frame-by-frame so I wanted to use the tracker. Is that possible? How? Thanks.
    Mike Clasby replied 19 years, 7 months ago 5 Members · 4 Replies
  • Paul Coull
    February 8, 2007 at 12:06 pm
    Try copying the tracking data from the footage layer to the mask layer.
    grafxflow
    grafx that flow!
  • Tyler Paul
    February 8, 2007 at 1:46 pm
    Can masks pick up that tracking data like that? I’m thinking it would treat the tracking info as vertices for the mask. If that doesn’t work, I’d put the mask on a white solid and apply the tracking info to it’s position. Then use this as a matte.
  • Tony Kloiber
    February 8, 2007 at 2:09 pm
    Tyler has your answer.
    You can’t apply tracking data to a mask shape directly at this time. So add mask to solid and I would parent the solid to a null that has received the tracking info. This way the mask doesn’t jump to a new location when the tracking info is applied and you can make small adjustments while keeping the overall move.
    I have the rant.
    This is one of the things people have wanted for… well you add in the length of time that is a appropriate for you.
    TonyTony
  • Mike Clasby
    February 8, 2007 at 6:44 pm
    Tyler and Tony’s method will work if the object doesn’t change shape over time, but there is a Script, that does what you want in all situations. It was written for roto work with the tracker. It does a great job, as good as the track you pull, lousy track=lousy roto, great track=great roto.
    Cue Fantasy Island music…
    Da Script… Da Script…
    You can control mask vertices with a script from harmdanpath, named RotAE.jsx, you can find it here:
    https://del.icio.us/escruz/Rotoscope
