Activity Forums VEGAS Pro How to apply the same Audio Event Fx to multiple clips?
  • How to apply the same Audio Event Fx to multiple clips?
    Posted by Heidi Huff on April 6, 2020 at 7:05 pm
    I have several audio clips on a track that I want to change the volume (db) to 4. What I normally do is I find each individual clip on the track, click the Fx in the right corner, click “volume” and type 4 in the text box. How can I do this for multiple clips at once instead of each individual clip at a time?
    I apologize if this has been asked before. I did try the search.
    Wayne Waag replied 6 years, 5 months ago 2 Members · 1 Reply
  • Wayne Waag
    April 7, 2020 at 5:24 am
    Make use of PasteEventAttributes. To do so, add the desired Fx to the first audio event. Then select the event and “Copy” (Ctrl-V). Then select the events to which you want to add the Fx. Once selected, right-click on any one of the new events and select “Paste Event Attributes”. The Fx you added to the first event will be added to the selected events. That’s it.
    wwaag
