Activity › Forums › DaVinci Resolve › How to apply LUT
How to apply LUT
Posted by Gergo Szabo on December 6, 2011 at 6:40 pmHi,
I have a footage shot with 7D and Technicolor CineStyle picture style. How can I apply the original LUT for it?
Garyps: I am noob in Davinci sry…
Thomas Worth replied 14 years, 9 months ago 6 Members · 10 Replies -
Gergo Szabo
December 6, 2011 at 10:29 pmI have found some advice in the earlier forum topics but they didn’t work. I copied the .cube file to the Library…./LUT folder. But It doesn’t show up on the list. I tried to click to the Update List button but nothing 🙁
Gary
Teo Rižnar
December 6, 2011 at 10:44 pmTry this: https://www.desktopvideoguy.com/2011/11/cinestyle-on-davinci-resolve-lite.html
I have not tested it jet. I got mine somewhere from this forum.
Color grade reel: https://vimeo.com/15480583
Cofounder of https://nuframe.si postproductionSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Dwaine Maggart
December 7, 2011 at 12:06 am.cube LUTs must go in the /LUT/Cinespace folder to be seen in the Resolve app.
.dat LUTs must go in the /LUT/Arri folder to be seen in the Resolve app.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Margus Voll
December 7, 2011 at 5:21 am/Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT/CineSpace/
I just did check the path from my machine where it is working.
Margus
Dwaine Maggart
December 7, 2011 at 7:11 pmI’m informed that .dat LUTs can also be placed in the LUT/Cinespace folder.
Dwaine Maggart
Teo Rižnar
December 7, 2011 at 9:48 pmBu tit needs to be in “DaVinci format” or form, how it is called officially LUT flavor for specific software (Color, DaVinci, Nuke, BaseLight,…)?
Pete Burger
December 8, 2011 at 2:09 pmCan’t help you with DaVinci but there’s a neat little program called 5DToRGB that is used to transcode the DSLR footage to other (more editable) codecs. In the newer versions it’s capable of applying the the LUT automatically to your footage if you want it to. Downside is: The look is “baked in” and you can’t remove it from the transcoded footage.
“Tragedy is a close-up; comedy, a long shot.” – Buster Keaton -
Gergo Szabo
December 8, 2011 at 2:18 pmThanks for all of your answers. It worked when I copied the file to the “CineSpace” folder.
Just one thing what I didn’t try yet. When I export everything. The LUT will be applied or I shuld use It again at the finishing (LUT Buddy)?
Gary -
Dwaine Maggart
December 8, 2011 at 11:06 pmIf you have the LUT anywhere EXCEPT as a Display LUT, it will be rendered.
Dwaine Maggart
Thomas Worth
December 9, 2011 at 5:37 pmYes, that’s correct. It is baked in, which isn’t appropriate for color grading. I added the CineStyle option to 5DtoRGB because several people requested it, but I actually don’t recommend it. If you’re going to grade later, then just transcode using the camera’s native matrix. In the case of Canon, it’s Rec. 601, full range. Other cameras (like the GH2) typically use Rec. 709, broadcast range.
Applying CineStyle during transcoding is only good for viewing dailies, in my opinion.
