Activity › Forums › Adobe Premiere Pro › how to apply effects to part of a video?? help
  • how to apply effects to part of a video?? help
    Posted by Michael Leggero on October 6, 2008 at 1:39 pm
    ok. i’ve got a video all imported and it’s on the timeline.. it’s about 10 mins long. how to i add an effect to start 2 mins into the video, and end after 3 mins??
    please be as simple in the description as you can be, i’m very new to this software.
    i’m using premiere pro cs3
    if anyone knows of GOOD free video tutorials that would be a huge help too
    Michael Leggero replied 17 years, 12 months ago 4 Members · 4 Replies
  • Eddie Lotter
    October 6, 2008 at 4:29 pm
    Use the razor tool to make a cut at the point where you want to start the effect and another cut where you want to end. Now apply the effect between those two cuts.
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Jeff Pulera
    October 6, 2008 at 5:34 pm
    Another tip when using Razor trick – add a cross dissolve at cut point to bring effect in gradually to avoid jump, works well for Color Correction for instance
    Jeff Pulera
    Safe Harbor
  • Ann Bens
    October 6, 2008 at 11:02 pm
    Or nest the video and keyframe the effect.
  • Michael Leggero
    October 7, 2008 at 11:20 am
    thanks!! that was so easy.. i knew it was something easy like that!! you guys rock!
