Activity Forums Adobe After Effects How to anti-alias flickering Hi-res graphics?
  • How to anti-alias flickering Hi-res graphics?
    Posted by Caspar Stracke on July 31, 2012 at 2:01 pm
    Dear Magicians,
    I am moving hi-res line-drawing images (>4K) and get the notorious flicker.
    First tried to reduce file size to 2x Comp size, still some flicker, build a mask and blurred the bas flickering areas manually but that looked worse than the original problem.
    Any suggestions?
    Always….VERY MUCH appreciated,
    C.S.
    Jeff Brown replied 14 years, 1 month ago 2 Members · 2 Replies
  • Caspar Stracke
    August 1, 2012 at 10:57 am
    Dear Dave,
    My comp is Full HD1080 and the files are 3636×2598.
    I guess thickening the lines is the best I can do. No magic deflickering trick?
    Much thanks as always,
    Caspar
  • Jeff Brown
    August 1, 2012 at 6:49 pm
    If you have lines on a solid background, appropriate keying followed by a negative matte choke might help.
    Or it might just be ugly…
    -Jeff
