Activity Forums Maxon Cinema 4D how to animate tube slice after making it editable
  • how to animate tube slice after making it editable
    Posted by Manny Rellesiva on September 4, 2013 at 5:37 am
    If I add tube object and turn on its “Slice”, I can animate its slice from a certain degree to another. However,if I make the tube object editable so that I could add details then I could no longer animate the “slice” options. How do I animate it, after making it editable? Please help. Im using cinema 4d V14.
    Manny Rellesiva replied 12 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    September 4, 2013 at 5:26 pm
    it’s probably easiest to use a Boole – probably using another Tube object to cut the first one – leave the cutter as a parametric object and animate it’s Slice parameters to get an animated boole of the tube you had to make editable.
  • Manny Rellesiva
    September 12, 2013 at 6:03 am
    thank you very much! this is a great help
