Activity Forums Maxon Cinema 4D how to animate the scale?!
  • how to animate the scale?!
    Posted by Manny Rellesiva on May 13, 2012 at 3:55 pm
    I posted this question days ago but =nobody responded. the questions didn’t seem to be too complicated. It’s as simple as how do you animate scale in an object. Say, u make an object editable then you try to select the scale tool to animate it, why does it failed to animate? However, when you choose the position record it will animate no problem the position of the object..am i missing something?
    manny
    Overture Cheng replied 14 years, 3 months ago 2 Members · 1 Reply
  • Overture Cheng
    May 14, 2012 at 2:48 am
    Make sure that u’re in object mode(Scaling the whole model NOT it’s points edges or nurbs).
