Activity › Forums › Adobe After Effects › how to animate grass
Posted by Bernd Rottenbuch on June 9, 2009 at 3:20 pmHi,
any suggestions how this effect was realized? My guess is either 3D/vue or a programmed effect.
https://www.daihatsu-greenpowered.it/It/Home/Home.html
greets
Roland R. kahlenberg replied 17 years, 2 months ago 4 Members · 7 Replies -
Steve Roberts
June 9, 2009 at 3:41 pmI suspect it was done in a 3D app with a hair/fur system, or Vue as you suggest.
June 9, 2009 at 3:48 pmIt would be a waste to use vue on this. It’s probably Photoshop or even Fractal Noise with some tinting. Google ‘grass, Photoshop and effect’ and see what you come up with.
Good Luck
RoRKbroadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
Adobe After Effects Training in South East Asia.
June 9, 2009 at 3:58 pmAAccck. I saw Steve’s name and his reply and I thought I should have another look-see. Yes, it does look realistic. So, yeah, Fractal Noise won’t be an ideal solution.
But a particle system using a custom particle with shading/lighting and perhaps Scatter should do the trick.
Cheers
David Bogie
June 9, 2009 at 4:46 pmJust a quick glance, the rollover effect is what you’re asking about? Looked like simple 2 or 3 frame burst of stills to me. You could do it with Scatter. But don’t forget to at least look at CC Hair, among the less understood and underused filters ever made for AE, second only perhaps to Ye Olde Compound Arithmetic.
bogiesan
Steve Roberts
June 9, 2009 at 6:18 pm[Roland R. Kahlenberg] “I saw Steve’s name and his reply and I thought I should have another look-see. “
Thanks, Roland.
S. -
June 10, 2009 at 4:13 amThe best way to animate grass is to smoke it. 🙂
RoRK
