Activity Forums Adobe After Effects How to animate a tennis ball roll
  • How to animate a tennis ball roll
    Posted by Ashley Davis on March 28, 2018 at 9:11 am
    I want to create an animation wherein a tennis ball rolls into frame and stops. Ideally, make it look realistic and that its rolling in 3d space rather than just moving into frame.
    Is there a relatively simple way of doing this? or even better, do stock vector videos/animations exist? Is this a thing?
    Thanks 🙂
    Steve Bentley replied 8 years, 5 months ago 3 Members · 2 Replies
  • Richard Garabedain
    March 28, 2018 at 2:37 pm
    well do you have element 3d? If not you could do a 2d animated roll.
  • Steve Bentley
    March 28, 2018 at 6:59 pm
    You could also use the CC sphere to simulate this but its a little tricky because it’s not really 3D.
    But just for a 2D ball , you can put an expression on the ball – you keyframe the rotation and then apply the math of: distanceTravelled = 2*Pie*R*rotationAngle/360
    I couldn’t figure out how to post the symbol for Pie
    R is the radius
    This way the balls “sticks” to the ground as it rolls and doesn’t spin at the wong rate.
