Activity Forums Adobe After Effects how to animate a shape in after effects
  • how to animate a shape in after effects
    Posted by Skyler Queenz on August 20, 2020 at 9:20 am
    Is it possible to animate that rectangle so that it can move in one direction only as i have highlighted in the image..when i try to animate the scale it moves in both sides.
    thank you in advance
    Robert Müller replied 6 years ago 3 Members · 2 Replies
  • Filip Vandueren
    August 20, 2020 at 11:08 am
    The simplest way is to convert it to a path and animate the path shape.
    Rectangle shapes are always drawn from their center so you need to animate both size and position to give the illusion of scaling from a corner.
  • Robert Müller
    August 20, 2020 at 1:25 pm
    You could also. move the Anchorpoint to the position where you want to scale “from”, so that it stays there. The problem with animating a converted path directly (at least as I see it) is that you lose your numeric values in the process.
