Activity › Forums › Apple Motion › How to alter timing/sizes in this template?
  • How to alter timing/sizes in this template?
    Posted by Kent Beeson on May 2, 2008 at 11:04 pm
    Hi
    New to Motion 3 – trying to alter a template – called “Large Format.HDV” – the one with three cropped boxes that slide into view, then out of view, then 3 more slide in…
    I want to start out with a clip full frame, then at 2 sec 21 frames I need it to shrink back to the default size of the template’s frame box #1, then the template’s box sizes can continue as they are – but I need also to alter timing – ie, need for the template’s boxes to be on screen longer before moving off…I’ve tried for 5 hours to figure this out, not sure the proper steps – how to place keyframes, where on which layer…can anyone help?
    Thanks much
    KB
    web.mac.com/kbcv
    Kent Beeson replied 18 years, 4 months ago 1 Member · 1 Reply
  • Kent Beeson
    May 3, 2008 at 1:52 am
    It’s actually Large Format.HD not HDV
    K
    KB
    web.mac.com/kbcv
