Activity Forums Adobe After Effects how to alter expression to affect only one axis
  • how to alter expression to affect only one axis
    Posted by Creativegoat on January 30, 2006 at 6:30 pm
    hi. this is my very first post.
    i want to use an expression to link an effect. as a default the expression affects x and y axis but i want it to be applied only to the x axis.
    (source of the effect are audio-keyframes, applied to the center of a simple tile effect)
    this is how it reads now:
    temp = thisComp.layer(“Audioamplitude”).effect(“Beide Kan
    Creativegoat replied 20 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 30, 2006 at 8:04 pm
    Try changing the second line to:
    [temp,value[1]]
    Dan
  • Roland R. kahlenberg
    January 30, 2006 at 8:10 pm
    Welcome! Just change the second occurrence of temp in the last line to value. I’ve bolded the change Imade to your script.
    // start of script
  • Creativegoat
    January 30, 2006 at 10:00 pm
    thanks, RoRK and Dan, that is it! I’m getting into it
