Activity Forums Adobe After Effects How to align path center to anchor point accurately
  • How to align path center to anchor point accurately
    Posted by jess Mah on December 2, 2024 at 2:02 pm
    Hi all – quick question that seems simple yet not:
    How do I accurately align the path center to the anchor point without having to eye ball it?
    I have aligned the path to the center of the screen and anchor points on the shape transform and the general transform are both at 0,0, but as soon as I rotate the path the anchor point appeared in a random place.
    Pls help
    Thanks in advance
    https://youtu.be/xgfr9xabEfE
    Nir Vanaskitz replied 1 year, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Cuevas
    December 2, 2024 at 5:09 pm
    Shape layers aren’t actually just the size of the shape, like if you made a new solid and it was 80×120 the anchor point would be at the center of that solid. Shape layers are the size of the entire comp size. So the anchor point isn’t for the actual shape, but the full layer size. Imagine you created a full solid, and could place your shape on it somewhere, the anchor point for the full solid is your anchor point. So when you centered that shape, you were moving the full shape layer and it’s anchor point isn’t at the center of your comp. It’s rotating at the 0,0 anchor point, it’s just that the anchor point is at 690.5, 462. You can fix this by rotating from within the shape layers transformations.
    Also, you can go into your edit/preferences/general and check “Center Anchor Point in New Shape Layers”. Then it won’t matter where you create the shape layer, the anchor point for the full layer size shape layer will be in the center of the shape you created.
  • jess Mah
    December 3, 2024 at 4:09 am
    Thanks for your reply, I tried your suggestion to turn center anchor on then off – seems like it didnt make any difference – am I missing something?
    Off
    https://youtu.be/cGymCRz5Xks
    On
    https://youtu.be/YF1vjA-n9LY
  • John Cuevas
    December 3, 2024 at 4:35 pm
    I’m getting the same result you do when I create lines and I’m not exactly sure why. If I create shapes using the shape tools, the anchor point is centered exactly as it should be, in the center of the shape(when the checked in the preferences). For lines, if you use the Transform tool for the layer, it rotates properly from the anchor point, but not if you rotate like you were within the shape contents transform. If you create a shape like a circle, square, you can use the Shape contents transform or the layer transform.
    The issue seems to be related to parametric shapes vs path shapes(created with pen tool).
  • jess Mah
    December 4, 2024 at 12:07 pm
    Thanks for your reply anyhow – really appreciate it. I think it might be a bug.
  • Theresa de Souza
    December 14, 2024 at 5:08 am
    If I’m understanding your question correctly … try Ctrl+Alt+Home. The center point should pop to the center of your line/shape.
  • jess Mah
    January 25, 2025 at 2:27 pm
    the usual snap-anchor- point-in-place command don’t seem to work when more than one shape nested under the same shape layer
  • Nir Vanaskitz
    January 25, 2025 at 2:46 pm
    Hi Jess, when multiple shapes are nested in the same layer, the Snap Anchor Point in Place might not work as expected. Instead, try selecting each shape’s individual Transform properties and manually align their paths to the layer’s anchor point. This should help center them accurately.
    — Nir-Vana
