Activity Forums VEGAS Pro How to adjust event length when changing properties>playback rate?
  • How to adjust event length when changing properties>playback rate?
    Posted by Carlos Silva on May 31, 2016 at 11:23 pm
    I would appreciate help:
    When I select event properties and change playback speed to 2.0, the event isn’t changing the length. I mean, Event length in normal playback speed has 10 minutes in the timeline. After increase properties>playback rate, event is still having 10 minutes. I was expecting event would change length to 5 minutes.
    Many Thanks!
    Carlos_
    Wayne Waag replied 10 years, 3 months ago 2 Members · 1 Reply
  • Wayne Waag
    June 1, 2016 at 3:22 am
    If you want to change the playback rate and adjust event length at the same time, simply Ctrl-drag the end of your event to the left. E.g. if you ctrl-drag a 1 min event to 30 sec, the playback rate will be 2.0.
    wwaag
