Activity Forums Avid Media Composer How to add two effects?
  • How to add two effects?
    Posted by Rocco Rocco on July 11, 2006 at 6:31 pm
    Avid Xpress 4.6
    Mac OS 10.4.5
    I need to flop and color correct a shot. When I drag flop into the shot, it works fine. Then when I drag color correct into it, it replaces the Flop; i.e. I can only use on effect at a time.
    Apols if this is a dumb question, but I cannot find the solution. thank you
    Dan O’brien replied 20 years, 2 months ago 2 Members · 1 Reply
  • Dan O’brien
    July 11, 2006 at 7:19 pm
    Just “alt” drag the flop ontop of the color correction. That way you’re nesting one effect inside the other. Or “step in” to the flop effect from your timeline, and add the color correction to the original clip.
    For more info, look up “nested effects” in the Avid manual, or click on the link below.
    https://www.avid.com/onlineSupport/supportcontent.asp?contentID=3225
